wafl.hya events
wafl.hya.aggr.policy.init
- Severity
INFORMATIONAL
 - Description
This message occurs when the default caching policies are to be configured on all volumes contained in this aggregate.
 - Corrective Action
(None).
 - Syslog Message
Attempting to configure the default caching policies on all volumes in the aggregate '%s %s'.
 - Parameters
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
wafl.hya.bc.add.cbi
- Severity
INFORMATIONAL
 - Description
This message occurs when a hybrid aggregate adds one counter file block (CBI - counter block index).
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
aggr (STRING): Aggregate name.
aggr_uuid (STRING): Universal Unique ID (UUID) of the aggregate.
volume (STRING): Volume name.
volume_uuid (STRING): UUID of the volume.
btid (INT): Buftree ID.
cbi (INT): CBI value.
volume_info (STRING): Volume type information.
wafl.hya.bc.del.flexvol
- Severity
INFORMATIONAL
 - Description
This message occurs when a hybrid aggregate block accounting module receives a FlexVol® deletion notification.
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
aggr_uuid (STRING): UUID of the aggregate.
cbi (INT): CBI (counter block index) value.
ctr0 (LONGINT): Counter 0, total used blocks by this buftree ID at the time of the delete event.
wafl.hya.bc.free.cbi
- Severity
INFORMATIONAL
 - Description
This message occurs when a hybrid aggregate block accounting module frees a CBI (counter block index).
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
ctr0 (LONGINT): Counter 0, total used blocks by this buftree ID at the time of the free event.
wafl.hya.cache.ret.policy
- Severity
INFORMATIONAL
 - Description
This message occurs when the cache retention priority policy for a volume in a hybrid aggregate has been modified.
 - Corrective Action
(None).
 - Syslog Message
Cache retention priority policy on volume '%s%s%s%s' has been modified to %s.
 - Parameters
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
cache_retention_priority (STRING): Cache retention priority policy configured on the volume.
wafl.hya.policy.init.skipped
- Severity
INFORMATIONAL
 - Description
This message occurs when cache policies could not be configured because of an invalid volume state.
 - Corrective Action
(None).
 - Syslog Message
Default caching policies were not set on volume '%s%s%s'.
 - Parameters
wafl.hya.rcache.policy
- Severity
INFORMATIONAL
 - Description
This message occurs when the read caching policy for a volume in a hybrid aggregate has been modified.
 - Corrective Action
(None).
 - Syslog Message
Read caching policy on volume '%s%s%s%s' has been modified to '%s'.
 - Parameters
read_policy (STRING): Read caching policy configured on the volume.
wafl.hya.sizer.warning
- Severity
NOTICE
 - Description
This message occurs when Flash Pool (tm) AWA (Automatic Workload Analyzer) encounters an abnormal condition such as low sampling rate or low memory resource.
 - Corrective Action
Contact NetApp technical support for assistance in resolving this issue.
 - Syslog Message
(None).
 - Parameters
event_info (STRING): Flash Pool (tm) Sizer warning information.
wafl.hya.wcache.policy
- Severity
INFORMATIONAL
 - Description
This message occurs when write caching policy for a volume in a hybrid aggregate has been modified.
 - Corrective Action
(None).
 - Syslog Message
Write caching policy on volume '%s%s%s%s' has been modified to '%s'.
 - Parameters
write_policy (STRING): Write caching policy configured on the volume.
