ONTAP EMS reference
wafl.hya events
wafl.hya EMS events occur when ONTAP encounters issues associated with hybrid aggregate caching policies and Flash Pool operations.
wafl.hya.aggr.policy.init
Severity
INFORMATIONAL
This message occurs when the default caching policies are to be configured on all volumes contained in this aggregate.
Corrective Action
(None).
Syslog Message
Attempting to configure the default caching policies on all volumes in the aggregate '%s %s'.
owner (STRING): Owner of the volume.
vol (STRING): Name of the volume.
wafl.hya.bc.add.cbi
Severity
INFORMATIONAL
This message occurs when a hybrid aggregate adds one counter file block (CBI - counter block index).
Corrective Action
(None).
Syslog Message
(None).
aggr (STRING): Aggregate name.
aggr_uuid (STRING): Universal Unique ID (UUID) of the aggregate.
volume (STRING): Volume name.
volume_uuid (STRING): UUID of the volume.
btid (LONGINT): Buftree ID.
cbi (INT): CBI value.
volume_info (STRING): Volume type information.
wafl.hya.bc.del.flexvol
Severity
INFORMATIONAL
This message occurs when a hybrid aggregate block accounting module receives a FlexVol® deletion notification.
Corrective Action
(None).
Syslog Message
(None).
aggr_uuid (STRING): UUID of the aggregate.
cbi (INT): CBI (counter block index) value.
ctr0 (LONGINT): Counter 0, total used blocks by this buftree ID at the time of the delete event.
wafl.hya.bc.free.cbi
Severity
INFORMATIONAL
This message occurs when a hybrid aggregate block accounting module frees a CBI (counter block index).
Corrective Action
(None).
Syslog Message
(None).
ctr0 (LONGINT): Counter 0, total used blocks by this buftree ID at the time of the free event.
wafl.hya.cache.ret.policy
Severity
INFORMATIONAL
This message occurs when the cache retention priority policy for a volume in a hybrid aggregate has been modified.
Corrective Action
(None).
Syslog Message
Cache retention priority policy on volume '%s%s%s%s' has been modified to %s.
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where the volume name itself is insufficient.
cache_retention_priority (STRING): Cache retention priority policy configured on the volume.
wafl.hya.policy.init.skipped
Severity
INFORMATIONAL
This message occurs when cache policies could not be configured because of an invalid volume state.
Corrective Action
(None).
Syslog Message
Default caching policies were not set on volume '%s%s%s'.
wafl.hya.rcache.policy
Severity
INFORMATIONAL
This message occurs when the read caching policy for a volume in a hybrid aggregate has been modified.
Corrective Action
(None).
Syslog Message
Read caching policy on volume '%s%s%s%s' has been modified to '%s'.
read_policy (STRING): Read caching policy configured on the volume.
wafl.hya.sizer.warning
Severity
NOTICE
This message occurs when Flash Pool (tm) AWA (Automatic Workload Analyzer) encounters an abnormal condition such as low sampling rate or low memory resource.
Corrective Action
Contact NetApp technical support for assistance in resolving this issue.
Syslog Message
(None).
event_info (STRING): Flash Pool (tm) Sizer warning information.
wafl.hya.wcache.policy
Severity
INFORMATIONAL
This message occurs when write caching policy for a volume in a hybrid aggregate has been modified.
Corrective Action
(None).
Syslog Message
Write caching policy on volume '%s%s%s%s' has been modified to '%s'.
write_policy (STRING): Write caching policy configured on the volume.
