ONTAP EMS reference
nvmens.512blksz events
NVMeNS.512blksz.repl.unsupp
Severity
ERROR
This message occurs when replication of a volume containing NVMe namespaces that use 512-byte block sizes fails because the destination does not support NVMe namespaces with this block size.
Corrective Action
Replicate volumes containing NVMe namespaces with 512-byte block sizes only to destinations that support namespaces that use this block size.
Syslog Message
Logical replication failed for volume %s (DSID %llu): No 512-byte block size NVMe namespace support on the destination.
volume_name (STRING): Name of the source volume.
volume_dsid (LONGINT): Data set ID (DSID) of the source volume.
