      perfstatd.disk events
perfstatd.disk.full
- Severity
ERROR
 - Description
This message occurs when the perfstat daemon (perfstatd) startup fails due to a full disk.This failure impacts the continuous archiving of performance data that technical support uses to troubleshoot performance issues.
 - Corrective Action
Verify that the '/mroot' file system is full by executing the 'df /mroot' command from the freebsd shell. After clearing some space, restart perfstatd by executing the 'spmctl -e -h perfstatd' command from the freebsd shell.
 - Syslog Message
The perfstat daemon startup failed due to a full disk.
 - Parameters
(None).
