ONTAP EMS reference
perfstatd.disk events
perfstatd.disk EMS events occur when the perfstat daemon (perfstatd) startup fails due to a full disk.This failure impacts the continuous archiving of performance data that technical support uses to troubleshoot performance issues.
perfstatd.disk.full
Severity
ERROR
This message occurs when the perfstat daemon (perfstatd) startup fails due to a full disk.This failure impacts the continuous archiving of performance data that technical support uses to troubleshoot performance issues.
Corrective Action
Verify that the '/mroot' file system is full by executing the 'df /mroot' command from the freebsd shell. After clearing some space, restart perfstatd by executing the 'spmctl -e -h perfstatd' command from the freebsd shell.
Syslog Message
The perfstat daemon startup failed due to a full disk.
(None).
