ONTAP EMS reference
ucm.mode events
ucm.mode EMS events occur when ONTAP encounters issues associated with FC adapter and converged networking adapter mode configuration.
ucm.mode.autoReboot
Severity
INFORMATIONAL
This message occurs when the FC adapter or converged networking adapter is reconfigured from a backup. The reconfiguration requires a reboot to enable correct adapter operation. The reboot occurs automatically.
Corrective Action
A change in the FC adapter or converged networking adapter mode configuration has occurred. The system is being rebooted to enable the new adapter configuration.
Syslog Message
Rebooting for adapters %s to become available.
adapters (STRING): Affected adapters.
ucm.mode.changed
Severity
INFORMATIONAL
This message occurs when the user changes the personality mode on a configurable adapter. The new mode will take effect on the next controller reboot.
Corrective Action
(None).
Syslog Message
Personality mode has changed to %s on adapter %s. Reboot the controller for the changes to take effect.
mode (STRING): Current adapter mode.
adapter (STRING): Name of the associated adapter.
ucm.mode.needsReboot
Severity
ERROR
This message occurs when the FC adapter or converged networking adapter is unable to automatically initiate a reboot after it reconfigures from a backup. The reconfiguration requires a reboot to enable correct adapter operation.
Corrective Action
Perform a planned takeover and giveback on this controller node to enable the new adapter configuration.
Syslog Message
The adapter %s was unable to automatically initiate a reboot after reconfiguration from the backup.
adapters (STRING): Affected adapter or adapters.
