ucm.mode events
Creating your file...
ucm.mode.autoReboot
- Severity
INFORMATIONAL
- Description
This message occurs when the FC adapter or converged networking adapter is reconfigured from a backup. The reconfiguration requires a reboot to enable correct adapter operation. The reboot occurs automatically.
- Corrective Action
A change in the FC adapter or converged networking adapter mode configuration has occurred. The system is being rebooted to enable the new adapter configuration.
- Syslog Message
Rebooting for adapters %s to become available.
- Parameters
adapters (STRING): Affected adapters.
ucm.mode.changed
- Severity
INFORMATIONAL
- Description
This message occurs when the user changes the personality mode on a configurable adapter. The new mode will take effect on the next controller reboot.
- Corrective Action
(None).
- Syslog Message
Personality mode has changed to %s on adapter %s. Reboot the controller for the changes to take effect.
- Parameters
mode (STRING): Current adapter mode.
adapter (STRING): Name of the associated adapter.
ucm.mode.needsReboot
- Severity
ERROR
- Description
This message occurs when the FC adapter or converged networking adapter is unable to automatically initiate a reboot after it reconfigures from a backup. The reconfiguration requires a reboot to enable correct adapter operation.
- Corrective Action
Perform a planned takeover and giveback on this controller node to enable the new adapter configuration.
- Syslog Message
The adapter %s was unable to automatically initiate a reboot after reconfiguration from the backup.
- Parameters
adapters (STRING): Affected adapter or adapters.
