The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
config.nopartnerdisks events
Creating your file...
Your file is ready
config.noPartnerDisks
- Severity
ERROR
- Description
This message occurs in a High-Availablity (HA> configuration when there are no partner disks.
- Corrective Action
Ensure that both nodes of the HA pair are cabled so they have access to all the disks. Check that the adapter interface to the disk shelves is up using the "storage adapter show" command. Ensure that any switches are correctly zoned for disk visibility by the nodes.
- Syslog Message
No disks were detected for the partner; this node cannot perform takeover correctly.
- Parameters
(None).
