The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cf.badshelfcountmsg events
Creating your file...
Your file is ready
cf.badShelfCountMsg
- Severity
ERROR
- Description
This event occurs if we are sent an invalid negotiated failover shelf count message. The message size is incorrect. This is likely due to an InterConnect problem.
- Corrective Action
Check for and resolve any interconnect errors. If the nodes are on different releases, upgrade the down-rev node.
- Syslog Message
Invalid disk shelf count message was received from partner.
- Parameters
(None).
