repl.s2c events
repl.s2c.checksum.mismatch
- Severity
ERROR
 - Description
This message occurs when the checksum of an object's contents does not match with the expected checksum.
 - Corrective Action
Please contact NetApp technical support for more options.
 - Syslog Message
Checksum mismatch in cloud object contents. Endpoint UUID = %s. Relationship UUID = %s. Object Name = %s. Slot ID = %d.
 - Parameters
epUuid (STRING): Endpoint UUID.
relnUuid (STRING): Relationship UUID.
objName (STRING): Cloud object name.
slotId (INT): Slot ID.
repl.s2c.rel.state.inconsistent
- Severity
EMERGENCY
 - Description
This message occurs when the replication source engine encounters a disk error in the relationship state metafile. Replication transfer will abort. Current relationship cannot be resumed.
 - Corrective Action
Current relationship cannot be resumed. Please create a new relationship.
 - Syslog Message
relationship state metafile inconsistent in volume '%s%s%s' due to disk errors. Aborting transfer.
 - Parameters
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Unique identifier of the volume in cases where the volume name itself is insufficient.
repl.s2c.restore.unsupported.config
- Severity
ERROR
 - Description
This message occurs when we encounter unsupported configuration during SnapMirror® restore.
 - Corrective Action
Cannot continue with restore.
 - Syslog Message
Cannot restore to volume '%s%s%s' because %s.
 - Parameters
reason (STRING): Specific reason for failure.
repl.s2c.restore.unsupported.snapshot
- Severity
ERROR
 - Description
This message occurs when we encounter unsupported source snapshot copy during SnapMirror® restore.
 - Corrective Action
Cannot use the source snapshot copy for SnapMirror® restore.
 - Syslog Message
Cannot restore from source snapshot copy to volume '%s%s%s' because %s.
 - Parameters
repl.s2c.rst.archv.data.fnd
- Severity
NOTICE
 - Description
This message occurs when SnapMirror® restore encounters data present in the cloud archive tier. SnapMirror restore cannot proceed until archival tier data processing has completed.
 - Corrective Action
Use the "snapmirror show" command to view the status of the processing of the archival tier of the cloud. When the relationship status becomes "Idle", then reissue the SnapMirror restore request.
 - Syslog Message
SnapMirror restore with transfer UUID "%s", cloud source endpoint UUID "%s", destination volume DSID "%llu", encountered data in the archival tier.
 - Parameters
transferId (STRING): SnapMirror transfer universal unique identifier (UUID).
srcEpUuid (STRING): Cloud source endpoint UUID.
dstVolDsid (LONGINT): Restore destination volume data set ID (DSID).
repl.s2c.src.inconsistent
- Severity
EMERGENCY
 - Description
This message occurs when the replication source engine encounters a disk error in the file system metadata. Replication transfer will abort.
 - Corrective Action
Run wafliron to fix the active file system. To continue replication transfer, run snapmirror abort -h command on the relationship, delete the current transfer snapshot copy and resume replication transfer from a new clean snapshot copy.
 - Syslog Message
WAFL metadata inconsistent in volume '%s%s%s' due to disk errors. Aborting transfer.
 - Parameters
repl.s2c.unsupported.config
- Severity
ERROR
 - Description
This message occurs when we encounter unsupported configuration during SnapMirror® backup.
 - Corrective Action
Cannot continue with backup.
 - Syslog Message
Cannot backup from volume '%s%s%s' because %s.
 - Parameters
repl.s2c.vmap.inconsistent
- Severity
INFORMATIONAL
 - Description
This message occurs when the replication source engine encounters a disk error in the replication specifc metadata. Replication transfer will abort.
 - Corrective Action
(None).
 - Syslog Message
Replication specific metadata inconsistency in volume '%s%s%s'. Aborting transfer. Transfer will attempt baseline to recover from this condition.
 - Parameters
