repl.s2c events
repl.s2c.checksum.mismatch
Severity
ERROR
This message occurs when the checksum of an object's contents does not match with the expected checksum.
Corrective Action
Please contact NetApp technical support for more options.
Syslog Message
Checksum mismatch in cloud object contents. Endpoint UUID = %s. Relationship UUID = %s. Object Name = %s. Slot ID = %d.
epUuid (STRING): Endpoint UUID.
relnUuid (STRING): Relationship UUID.
objName (STRING): Cloud object name.
slotId (INT): Slot ID.
repl.s2c.rel.state.inconsistent
Severity
EMERGENCY
This message occurs when the replication source engine encounters a disk error in the relationship state metafile. Replication transfer will abort. Current relationship cannot be resumed.
Corrective Action
Current relationship cannot be resumed. Please create a new relationship.
Syslog Message
relationship state metafile inconsistent in volume '%s%s%s' due to disk errors. Aborting transfer.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Unique identifier of the volume in cases where the volume name itself is insufficient.
repl.s2c.restore.unsupported.config
Severity
ERROR
This message occurs when we encounter unsupported configuration during SnapMirror® restore.
Corrective Action
Cannot continue with restore.
Syslog Message
Cannot restore to volume '%s%s%s' because %s.
reason (STRING): Specific reason for failure.
repl.s2c.restore.unsupported.snapshot
Severity
ERROR
This message occurs when we encounter unsupported source snapshot copy during SnapMirror® restore.
Corrective Action
Cannot use the source snapshot copy for SnapMirror® restore.
Syslog Message
Cannot restore from source snapshot copy to volume '%s%s%s' because %s.
repl.s2c.rst.archv.data.fnd
Severity
NOTICE
This message occurs when SnapMirror® restore encounters data present in the cloud archive tier. SnapMirror restore cannot proceed until archival tier data processing has completed.
Corrective Action
Use the "snapmirror show" command to view the status of the processing of the archival tier of the cloud. When the relationship status becomes "Idle", then reissue the SnapMirror restore request.
Syslog Message
SnapMirror restore with transfer UUID "%s", cloud source endpoint UUID "%s", destination volume DSID "%llu", encountered data in the archival tier.
transferId (STRING): SnapMirror transfer universal unique identifier (UUID).
srcEpUuid (STRING): Cloud source endpoint UUID.
dstVolDsid (LONGINT): Restore destination volume data set ID (DSID).
repl.s2c.src.inconsistent
Severity
EMERGENCY
This message occurs when the replication source engine encounters a disk error in the file system metadata. Replication transfer will abort.
Corrective Action
Run wafliron to fix the active file system. To continue replication transfer, run snapmirror abort -h command on the relationship, delete the current transfer snapshot copy and resume replication transfer from a new clean snapshot copy.
Syslog Message
WAFL metadata inconsistent in volume '%s%s%s' due to disk errors. Aborting transfer.
repl.s2c.unsupported.config
Severity
ERROR
This message occurs when we encounter unsupported configuration during SnapMirror® backup.
Corrective Action
Cannot continue with backup.
Syslog Message
Cannot backup from volume '%s%s%s' because %s.
repl.s2c.vmap.inconsistent
Severity
INFORMATIONAL
This message occurs when the replication source engine encounters a disk error in the replication specifc metadata. Replication transfer will abort.
Corrective Action
(None).
Syslog Message
Replication specific metadata inconsistency in volume '%s%s%s'. Aborting transfer. Transfer will attempt baseline to recover from this condition.
