ONTAP EMS reference
reg.errno events
reg.errno EMS events occur when ONTAP encounters issues associated with adding errno-style errors to the error list.
reg.errno.addAfterReadable
Severity
NOTICE
This event is issued when Data ONTAP(tm) cannot add an errno-style error to the list of errors. The error must be added before the readable version is generated. No action by the system administrator is needed.
Corrective Action
(None).
Syslog Message
registry: ignoring attempt to add an error (%d) after errors_readable was called.
errnoval (INT): The numerical value of the error.
reg.errno.addInvalid
Severity
NOTICE
This event is issued when Data ONTAP(tm) cannot add an errno-style error to the list of errors. The error number must be non-zero or the error string must be non-NULL. No action by the system administrator is needed.
Corrective Action
(None).
Syslog Message
registry: in errors_add_real, errnoval must be non-zero or str must be non-NULL.
(None).
