reg.errno events
Creating your file...
Your file is ready
reg.errno.addAfterReadable
- Severity
NOTICE
- Description
This event is issued when Data ONTAP(tm) cannot add an errno-style error to the list of errors. The error must be added before the readable version is generated. No action by the system administrator is needed.
- Corrective Action
(None).
- Syslog Message
registry: ignoring attempt to add an error (%d) after errors_readable was called.
- Parameters
errnoval (INT): The numerical value of the error.
reg.errno.addInvalid
- Severity
NOTICE
- Description
This event is issued when Data ONTAP(tm) cannot add an errno-style error to the list of errors. The error number must be non-zero or the error string must be non-NULL. No action by the system administrator is needed.
- Corrective Action
(None).
- Syslog Message
registry: in errors_add_real, errnoval must be non-zero or str must be non-NULL.
- Parameters
(None).
