auto.cds events
auto.cds.feature.disable.failed
Severity
INFORMATIONAL
This message occurs during upgrade to Data ONTAP® 9.11.1 or later, when volume efficiency inactive data compression scan disablement failed on the existing compatible volumes.
Corrective Action
Manually try disabling the inline Volume Efficiency Inactive data compression on the volume using the "volume efficiency inactive-data-compression" command.
Syslog Message
Volume Inactive Data Compression disablement failed on Volume %s of Vserver %s.
volume (STRING): Volume name.
vserver (STRING): Vserver name.
reason (STRING): Reason for failure.
auto.cds.feature.disable.success
Severity
INFORMATIONAL
This message occurs during upgrade to Data ONTAP® 9.11.1 or later, when volume efficiency inactive data compression scan is disabled on the existing compatible volumes.
Corrective Action
(None).
Syslog Message
Volume Inactive Data Compression disabled on Volume %s of Vserver %s.
