auto.cds events
Creating your file...
auto.cds.feature.disable.failed
- Severity
INFORMATIONAL
- Description
This message occurs during upgrade to Data ONTAP® 9.11.1 or later, when volume efficiency inactive data compression scan disablement failed on the existing compatible volumes.
- Corrective Action
Manually try disabling the inline Volume Efficiency Inactive data compression on the volume using the "volume efficiency inactive-data-compression" command.
- Syslog Message
Volume Inactive Data Compression disablement failed on Volume %s of Vserver %s.
- Parameters
volume (STRING): Volume name.
vserver (STRING): Vserver name.
reason (STRING): Reason for failure.
auto.cds.feature.disable.success
- Severity
INFORMATIONAL
- Description
This message occurs during upgrade to Data ONTAP® 9.11.1 or later, when volume efficiency inactive data compression scan is disabled on the existing compatible volumes.
- Corrective Action
(None).
- Syslog Message
Volume Inactive Data Compression disabled on Volume %s of Vserver %s.
- Parameters
