ctran.group events
ctran.group EMS events occur when an attempt to reset a group by Kernel Cluster Services (KCS) Cluster Transaction Manager (CTRAN) fails.
ctran.group.reset.failed
- Severity
EMERGENCY
- Description
This message occurs when an attempt to reset a group by Kernel Cluster Services (KCS) Cluster Transaction Manager (CTRAN) fails.
- Corrective Action
KCS CTRAN logs will need to be collected for further analysis. Trigger an ALL autosupport by using "autosupport invoke -node * -message "ctran.group.reset.failed" -type all", a diagnostic autosupport by using "autosupport invoke-diagnostic -node * -message "ctran.group.reset.failed" -subsystem kcs" and contact NetApp technical support support.
- Syslog Message
Group reset for %s has failed on node %s.
- Parameters
localhostname (STRING): The host name of the local node.
group_name (STRING): The group on which the group reset operation is attempted.
