ctran.group events
ctran.group.reset.failed
Severity
EMERGENCY
This message occurs when an attempt to reset a group by Kernel Cluster Services (KCS) Cluster Transaction Manager (CTRAN) fails.
Corrective Action
KCS CTRAN logs will need to be collected for further analysis. Trigger an ALL autosupport by using "autosupport invoke -node * -message "ctran.group.reset.failed" -type all", a diagnostic autosupport by using "autosupport invoke-diagnostic -node * -message "ctran.group.reset.failed" -subsystem kcs" and contact NetApp technical support support.
Syslog Message
Group reset for %s has failed on node %s.
localhostname (STRING): The host name of the local node.
group_name (STRING): The group on which the group reset operation is attempted.
