The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
license.sfo events
Creating your file...
Your file is ready
license.sfo.gb.veto
- Severity
ERROR
- Description
This message occurs when a storage failover giveback is vetoed because a select capacity license has not been installed and the license installation grace period has ended.
- Corrective Action
Install a valid select capacity license, and then reissue the "storage failover giveback" command. Use the "system license show-status" command to determine which node is missing the capacity license.
- Syslog Message
SFO giveback vetoed. Missing select capacity license.
- Parameters
(None).
license.sfo.gb.veto.eval
- Severity
ERROR
- Description
This message occurs when a storage failover giveback is vetoed because the evaluation period for the ONTAP ® instance has ended.
- Corrective Action
Contact your sales representative for further assistance.
- Syslog Message
SFO giveback vetoed. Evaluation period ended.
- Parameters
(None).
