      license.sfo events
license.sfo.gb.veto
- Severity
ERROR
 - Description
This message occurs when a storage failover giveback is vetoed because a select capacity license has not been installed and the license installation grace period has ended.
 - Corrective Action
Install a valid select capacity license, and then reissue the "storage failover giveback" command. Use the "system license show-status" command to determine which node is missing the capacity license.
 - Syslog Message
SFO giveback vetoed. Missing select capacity license.
 - Parameters
(None).
license.sfo.gb.veto.eval
- Severity
ERROR
 - Description
This message occurs when a storage failover giveback is vetoed because the evaluation period for the ONTAP ® instance has ended.
 - Corrective Action
Contact your sales representative for further assistance.
 - Syslog Message
SFO giveback vetoed. Evaluation period ended.
 - Parameters
(None).
