snaplock.state events
Creating your file...
Your file is ready
snaplock.state.dir.destroyFail
- Severity
NOTICE
- Description
This event is generated if SnapLock is unable to destroy the SnapLock state for a SnapLock volume. This will not affect the operation of the reverted volume and does not require any corrective action.
- Corrective Action
(None).
- Syslog Message
Failed to destroy the SnapLock state for SnapLock volume '%s%s' on the Vserver with ID '%s'.
- Parameters
volume (STRING): The name of the SnapLock volume on which the SnapLock state could not be destroyed.
app (STRING): Application Name.
volident (STRING): Unique identifier of the volume when the volume name itself is insufficient.
