The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
snaplock.state events
Creating your file...
Your file is ready
snaplock.state.dir.destroyFail
- Severity
NOTICE
- Description
This event is generated if SnapLock is unable to destroy the SnapLock state for a SnapLock volume. This will not affect the operation of the reverted volume and does not require any corrective action.
- Corrective Action
(None).
- Syslog Message
Failed to destroy the SnapLock state for SnapLock volume '%s%s' on the Vserver with ID '%s'.
- Parameters
volume (STRING): The name of the SnapLock volume on which the SnapLock state could not be destroyed.
app (STRING): Application Name.
volident (STRING): Unique identifier of the volume when the volume name itself is insufficient.
