master.taking events
master.taking EMS events occur when a node is promoted to the cluster master and takes control as master.
master.taking.over.cm
- Severity
NOTICE
- Description
This message occurs when the node is promoted to the cluster master and takes control as the master.
- Corrective Action
(None).
- Syslog Message
Service ID %u on node ID %u (UUID: %s) takes over as the cluster master.
- Parameters
serviceID (INT): Service ID that identifies the associated master service.
nodeID (INT): Node ID number of the associated node.
nodeUuid (STRING): Node UUID of the associated node.
