ONTAP EMS reference
master.taking events
master.taking EMS events occur when a node is promoted to the cluster master and takes control as the master.
master.taking.over.cm
Severity
NOTICE
This message occurs when the node is promoted to the cluster master and takes control as the master.
Corrective Action
(None).
Syslog Message
Service ID %u on node ID %u (UUID: %s) takes over as the cluster master.
serviceID (INT): Service ID that identifies the associated master service.
nodeID (INT): Node ID number of the associated node.
nodeUuid (STRING): Node UUID of the associated node.
