The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
monitor.weeklystatsasup events
Creating your file...
Your file is ready
monitor.weeklyStatsASUP.off
- Severity
ERROR
- Description
This message occurs when weekly performance AutoSupport(tm) is disabled.
- Corrective Action
Enable the weekly performance AutoSupport by entering the "options stats.autosupport.weekly.enable on" command. You must have the correct privilege to run this command.
- Syslog Message
Weekly performance AutoSupport has been disabled.
- Parameters
(None).
