ONTAP EMS reference
hamsg.diskcheckresp events
hamsg.diskcheckresp EMS events occur when a node receives a disk inventory check response from its high-availability (HA) partner.
hamsg.diskCheckResp
Severity
NOTICE
This message occurs when a node receives a disk inventory check response from its high-availability (HA) partner.
Corrective Action
(None).
Syslog Message
The local node has received a disk inventory check response (%d) from its HA partner.
response (INT): The disk inventory check response received from the HA partner.
