ONTAP EMS reference
usb.port events
usb.port.error
Severity
ERROR
This message occurs when the Data ONTAP® universal serial bus (USB) adapter driver detects an unrecoverable error on the associated port.
Corrective Action
If a device is attached to the associated port, try reinserting the device. If that fails, try replacing the device. If the problem persists, contact NetApp technical support for assistance in diagnosing a USB issue.
Syslog Message
In adapter %s, unrecoverable error detected for port %d. Ignoring attached device.
adapterName (STRING): Name of the associated USB adapter.
port (INT): Associated port number.
