ONTAP EMS reference
scsiblade.kernel events
scsiblade.kernel EMS events occur when ONTAP encounters issues associated with kernel cluster groups for volumes or Vservers.
scsiblade.kernel.volume.limbo.group
Severity
EMERGENCY
This message occurs when the kernel cluster group for the specified volume is in an indeterminate state.
Corrective Action
Contact NetApp technical support. For further information about correcting the problem, see the knowledgebase article 2017368.
Syslog Message
The kernel cluster group for volume MSID 0x%llx of Vserver %s is in an indeterminate state. This will impact SAN management and configuration. Additionally, LUNs might not be accessible on this volume from this node.
volume (LONGINTHEX): Volume identifier.
vserver (STRING): UUID of the Vserver.
scsiblade.kernel.vserver.limbo.group
Severity
EMERGENCY
This message occurs when the kernel cluster group for the specified Vserver is in an indeterminate state.
Corrective Action
Contact NetApp technical support. For further information about correcting the problem, see the Knowledgebase article 2017367.
Syslog Message
The kernel cluster group for Vserver %s is in an indeterminate state. This will impact SAN management and configuration. Additionally, LUNs might not be accessible on this Vserver from this node.
