ONTAP EMS reference
dbs.unresponsive events
dbs.unresponsive EMS events occur when Distributed Block Store (DBS) detects an unresponsive service.
dbs.unresponsive.service.alrt
Severity
ALERT
This message occurs when Distributed Block Store (DBS) Master Service detects an unresponsive service.
Corrective Action
Wait 10 minutes and check that the fault status has changed to Resolved. If the condition persists, contact NetApp technical support.
Syslog Message
DBS has detected an unresponsive service. Cluster fault service ID %u, node %u, node UUID %s, type %s, fault ID %u, status %u. %s
serviceID (INT): Service ID that identifies the associated cluster service.
nodeID (INT): Node ID number of the associated node.
nodeUUID (STRING): Node UUID string of the associated node.
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Name of the affected service.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the CreateClusterFault API command and attached to the fault for testing purposes.
dbs.unresponsive.service.err
Severity
ERROR
This message occurs when Distributed Block Store (DBS) detects an unresponsive service.
Corrective Action
Verify that the service is restarted within 10 minutes.
Syslog Message
