dbs.unresponsive events
dbs.unresponsive.service.alrt
- Severity
ALERT
 - Description
This message occurs when Distributed Block Store (DBS) Master Service detects an unresponsive service.
 - Corrective Action
Wait 10 minutes and check that the fault status has changed to Resolved. If the condition persists, contact NetApp technical support.
 - Syslog Message
DBS has detected an unresponsive service. Cluster fault service ID %u, node %u, node UUID %s, type %s, fault ID %u, status %u. %s
 - Parameters
serviceID (INT): Service ID that identifies the associated cluster service.
nodeID (INT): Node ID number of the associated node.
nodeUuid (STRING): Node UUID string of the associated node.
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Name of the affected service.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the CreateClusterFault API command and attached to the fault for testing purposes.
dbs.unresponsive.service.err
- Severity
ERROR
 - Description
This message occurs when Distributed Block Store (DBS) detects an unresponsive service.
 - Corrective Action
Verify that the service is restarted within 10 minutes.
 - Syslog Message
 - Parameters
