ONTAP EMS reference
vifmgr.portowner events
vifmgr.portowner EMS events occur when a port receives a configuration error.
vifmgr.portowner.err
Severity
ERROR
This message occurs when a port receives a configuration error.
Corrective Action
Remove any ports from the bootarg.bsdportname LOADER variable that are of a role other than node-mgmt by resetting the bootarg.bsdportname under the LOADER prompt: LOADER> setenv bootarg.bsdportname "port-name (node-mgmt port only)" Then reboot the node.
Syslog Message
Node %s port %s has an invalid port role type. Only node-mgmt network ports can be assigned to use a different driver.
nodename (STRING): Name of the node on which the affected port resides.
portname (STRING): Name of the affected port.
