The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
adt.cmdthrd events
Creating your file...
Your file is ready
adt.cmdthrd.create.fail
- Severity
ALERT
- Description
This message occurs when audit initialization fails because the necessary execution threads cannot be created.
- Corrective Action
Available system resources are required for this feature to function. The best way to accomplish that is through a system reboot. For HA configurations, operational disruption can be minimized by initiating a partner takeover followed by a reboot of this partner. After the reboot is complete, issue a "giveback" command to return services to this partner.
- Syslog Message
Audit subsystem internal error: Could not start required audit command threads, system reboot might be required.
- Parameters
(None).
