The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
netif.nicnotsupported events
Creating your file...
Your file is ready
netif.nicNotSupported
- Severity
ERROR
- Description
This message occurs when the installed network interface card (NIC) version is not supported.
- Corrective Action
Replace the NIC with one purchased from NetApp.
- Syslog Message
The NIC in slot %d is not supported. The %s is not supported.
- Parameters
slot (INT): Slot number of the NIC.
reason (STRING): Specific reason the NIC is not supported.
