asyncdelete.message events
asyncDelete.message.fail
- Severity
ALERT
- Description
This message occurs when an async delete job fails.
- Corrective Action
Ensure that all nodes in the cluster are online and healthy, and that all volumes needed for the directory traversal are online. Then retry the operation.
- Syslog Message
Async delete job on path %s of volume (MSID: %llu) failed: %s.
- Parameters
path (STRING): Path to be deleted.
volume_msid (LONGINT): MSID of the volume containing the directory.
error (STRING): Description of the error that occurred.
asyncDelete.message.start
- Severity
NOTICE
- Description
This message occurs when an async delete job starts on the path specified.
- Corrective Action
(None).
- Syslog Message
Async delete job started on path %s of volume (MSID: %llu).
- Parameters
asyncDelete.message.success
- Severity
NOTICE
- Description
This message occurs when an async delete job finishes successfully on the specified path.
- Corrective Action
(None).
- Syslog Message
Async delete job on path %s of volume (MSID: %llu) was completed. Number of files deleted: %llu, Number of directories deleted: %llu. Total number of bytes deleted: %llu.
- Parameters
file_count (LONGINT): Total number of files deleted.
dir_count (LONGINT): Total number of directories deleted.
deleted_size (LONGINT): Total number of bytes deleted.
