asyncdelete.message events
asyncDelete.message.fail
Severity
ALERT
This message occurs when an async delete job fails.
Corrective Action
Ensure that all nodes in the cluster are online and healthy, and that all volumes needed for the directory traversal are online. Then retry the operation.
Syslog Message
Async delete job on path %s of volume (MSID: %llu) failed: %s.
path (STRING): Path to be deleted.
volume_msid (LONGINT): MSID of the volume containing the directory.
error (STRING): Description of the error that occurred.
asyncDelete.message.start
Severity
NOTICE
This message occurs when an async delete job starts on the path specified.
Corrective Action
(None).
Syslog Message
Async delete job started on path %s of volume (MSID: %llu).
asyncDelete.message.success
Severity
NOTICE
This message occurs when an async delete job finishes successfully on the specified path.
Corrective Action
(None).
Syslog Message
Async delete job on path %s of volume (MSID: %llu) was completed. Number of files deleted: %llu, Number of directories deleted: %llu. Total number of bytes deleted: %llu.
file_count (LONGINT): Total number of files deleted.
dir_count (LONGINT): Total number of directories deleted.
deleted_size (LONGINT): Total number of bytes deleted.
