The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
callhome.unsupported events
Creating your file...
Your file is ready
callhome.unsupported.snaplock
- Severity
ALERT
- Description
This message occurs when the system generates an AutoSupport event to notify you that a SnapLock® disk is attached to a system running a release of ONTAP® that does not support SnapLock.
- Corrective Action
Remove the SnapLock disks from this system and attach them to a system that supports SnapLock. You can also revert or upgrade this system to a release that supports SnapLock.
- Syslog Message
Call home for SNAPLOCK DISKS IN UNSUPPORTED RELEASE
- Parameters
subject (STRING): AutoSupport subject or title for this event.
