config.more2path events
config.More2Path
- Severity
ERROR
- Description
This message occurs when a disk is found to have more than two connections to the storage controller.
- Corrective Action
Remove connections to the disk so there are only two.
- Syslog Message
Disk %s and other disks on this loop/domain are attached with more than two connections. Only two connections are supported.
- Parameters
disk (STRING): Name of the disk.
