netif.overtemperror events
netif.overTempError
- Severity
EMERGENCY
- Description
This message occurs when a network port is too hot or a sensor has malfunctioned. Depending on how the port is deployed, the failure may disrupt user data access, node access or cluster communication.
- Corrective Action
Ensure adequate cooling and ventilation is available. If that does not resolve the issue, replace the failed card.
- Syslog Message
Network port %s is over temperature.
- Parameters
ifName (STRING): Name of the network port: for example, "e4a".
