      netif.overtemperror events
netif.overTempError
- Severity
EMERGENCY
 - Description
This message occurs when a network port is too hot or a sensor has malfunctioned. Depending on how the port is deployed, the failure may disrupt user data access, node access or cluster communication.
 - Corrective Action
Ensure adequate cooling and ventilation is available. If that does not resolve the issue, replace the failed card.
 - Syslog Message
Network port %s is over temperature.
 - Parameters
ifName (STRING): Name of the network port: for example, "e4a".
