ONTAP EMS reference
netif.overtemperror events
netif.overTempError
Severity
EMERGENCY
This message occurs when a network port is too hot or a sensor has malfunctioned. Depending on how the port is deployed, the failure may disrupt user data access, node access or cluster communication.
Corrective Action
Ensure adequate cooling and ventilation is available. If that does not resolve the issue, replace the failed card.
Syslog Message
Network port %s is over temperature.
ifName (STRING): Name of the network port: for example, "e4a".
