adt.nfs events
adt.nfs.root.access.no.map
Severity
ERROR
This message occurs in the auditing subsytem, when the NFS root user is accessing the file without a valid CIFS credential. Access is being allowed because the "ignore-nt-acl-for-root" NFS option is set, and hence the BUILTIN\Administrator credential is used for auditing.
Corrective Action
If NFS root user access to the file without NT ACL check should be prohibited, disable the "ignore-nt-act-for-root" option by using the "nfs modify -ignore-nt-acl-for-root" command. If a more appropriate CIFS credential should be used for auditing, configure the SVM name-mapping by using the "vserver name-mapping" command.
Syslog Message
VserverUuid (STRING): UUID of the Storage Virtual Machine (SVM, formerly Vserver).
