adt.nfs events
adt.nfs.root.access.no.map
- Severity
ERROR
 - Description
This message occurs in the auditing subsytem, when the NFS root user is accessing the file without a valid CIFS credential. Access is being allowed because the "ignore-nt-acl-for-root" NFS option is set, and hence the BUILTIN\Administrator credential is used for auditing.
 - Corrective Action
If NFS root user access to the file without NT ACL check should be prohibited, disable the "ignore-nt-act-for-root" option by using the "nfs modify -ignore-nt-acl-for-root" command. If a more appropriate CIFS credential should be used for auditing, configure the SVM name-mapping by using the "vserver name-mapping" command.
 - Syslog Message
 - Parameters
VserverUuid (STRING): UUID of the Storage Virtual Machine (SVM, formerly Vserver).
