ONTAP EMS reference
sas.initialization events
sas.initialization EMS events occur when the SAS adapter failed to initialize the link and appears to be unattached/disconnected.
sas.initialization.failed
Severity
ERROR
The SAS adapter failed to initialize the link and appears to be unattached/disconnected.
Corrective Action
If the adapter is in use check cabling and if connected to disk shelves check the seating of IOM cards.
Syslog Message
Initialization failed on SAS adapter %s.
adapterName (STRING): The name of the associated SAS host bus adapter.
