sas.initialization events
Creating your file...
Your file is ready
sas.initialization.failed
- Severity
ERROR
- Description
The SAS adapter failed to initialize the link and appears to be unattached/disconnected.
- Corrective Action
If the adapter is in use check cabling and if connected to disk shelves check the seating of IOM cards.
- Syslog Message
Initialization failed on SAS adapter %s.
- Parameters
adapterName (STRING): The name of the associated SAS host bus adapter.
