The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
sas.initialization events
Creating your file...
Your file is ready
sas.initialization.failed
- Severity
ERROR
- Description
The SAS adapter failed to initialize the link and appears to be unattached/disconnected.
- Corrective Action
If the adapter is in use check cabling and if connected to disk shelves check the seating of IOM cards.
- Syslog Message
Initialization failed on SAS adapter %s.
- Parameters
adapterName (STRING): The name of the associated SAS host bus adapter.
