sfu.auto events
sfu.auto.update.off.impact
Severity
ERROR
This message occurs when ONTAP® software cannot automatically upgrade the firmware on a disk shelf because the hidden 'shelf.fw.auto.update' option is set to off.
Corrective Action
Set the hidden option 'shelf.fw.auto.update' to "on", or update the firmware manually.
Syslog Message
Firmware could not be updated on I/O module %s with firmware version %s on %s disk shelf %s.shelf%d. Update the firmware manually.
moduleType (STRING): I/O controller module type, for example, AT-FCX/ESH4/SAS/IOM3.
productRev (STRING): Firmware revision level.
shelfType (STRING): Disk shelf enclosure type, for example, DS14-Mk4-FC, DS14-Mk2-FC, or DS14-Mk2-AT.
channelName (STRING): Name of the adapter port or switch port of the disk shelf enclosure.
shelfId (INT): ID of the disk shelf enclosure.
