sfu.auto events
Creating your file...
sfu.auto.update.off.impact
- Severity
ERROR
- Description
This message occurs when ONTAP® software cannot automatically upgrade the firmware on a disk shelf because the hidden 'shelf.fw.auto.update' option is set to off.
- Corrective Action
Set the hidden option 'shelf.fw.auto.update' to "on", or update the firmware manually.
- Syslog Message
Firmware could not be updated on I/O module %s with firmware version %s on %s disk shelf %s.shelf%d. Update the firmware manually.
- Parameters
moduleType (STRING): I/O controller module type, for example, AT-FCX/ESH4/SAS/IOM3.
productRev (STRING): Firmware revision level.
shelfType (STRING): Disk shelf enclosure type, for example, DS14-Mk4-FC, DS14-Mk2-FC, or DS14-Mk2-AT.
channelName (STRING): Name of the adapter port or switch port of the disk shelf enclosure.
shelfId (INT): ID of the disk shelf enclosure.
