upgrademgr.update events
Creating your file...
upgrademgr.update.cancelled
- Severity
INFORMATIONAL
- Description
This message occurs when the automated update of the cluster is canceled by the operator.
- Corrective Action
(None).
- Syslog Message
The automated update of the cluster has been canceled by the operator.
- Parameters
(None).
upgrademgr.update.completed
- Severity
INFORMATIONAL
- Description
This message occurs when the automated update of the cluster is complete.
- Corrective Action
(None).
- Syslog Message
The automated update of the cluster is complete.
- Parameters
(None).
upgrademgr.update.pausedErr
- Severity
ERROR
- Description
This message occurs when the automated update of the cluster is paused as a result of an error.
- Corrective Action
The automated update of the cluster has been paused due to the following reason: %s. Correct the cause of the error, and then issue the "cluster image resume-update" command to continue the automated update of the cluster.
- Syslog Message
- Parameters
pausedSummary (STRING): Summary of the event causing the paused update.
upgrademgr.update.pausedUser
- Severity
INFORMATIONAL
- Description
This message occurs when the automated update of the cluster is paused as a result of an operator request.
- Corrective Action
Issue the "cluster image resume-update" command to continue the automated update of the cluster.
- Syslog Message
The automated update of the cluster has been paused due to a request by the operator.
- Parameters
(None).
upgrademgr.update.resumed
- Severity
INFORMATIONAL
- Description
This message occurs when the automated update of the cluster is resumed from the paused state.
- Corrective Action
(None).
- Syslog Message
The automated update of the cluster has been resumed by the operator.
- Parameters
(None).
upgrademgr.update.started
- Severity
INFORMATIONAL
- Description
This message occurs when the upgrade manager begins an automated update of the cluster.
- Corrective Action
(None).
- Syslog Message
An automated update of the cluster has been started.
- Parameters
(None).
