ONTAP EMS reference
upgrademgr.update events
upgrademgr.update EMS events occur when ONTAP encounters issues associated with automated cluster update operations.
upgrademgr.update.cancelled
Severity
INFORMATIONAL
This message occurs when the automated update of the cluster is canceled by the operator.
Corrective Action
(None).
Syslog Message
The automated update of the cluster has been canceled by the operator.
(None).
upgrademgr.update.completed
Severity
INFORMATIONAL
This message occurs when the automated update of the cluster is complete.
Corrective Action
(None).
Syslog Message
The automated update of the cluster is complete.
(None).
upgrademgr.update.pausedErr
Severity
ERROR
This message occurs when the automated update of the cluster is paused as a result of an error.
Corrective Action
The automated update of the cluster has been paused due to the following reason: %s. Correct the cause of the error, and then issue the "cluster image resume-update" command to continue the automated update of the cluster.
Syslog Message
pausedSummary (STRING): Summary of the event causing the paused update.
upgrademgr.update.pausedUser
Severity
INFORMATIONAL
This message occurs when the automated update of the cluster is paused as a result of an operator request.
Corrective Action
Issue the "cluster image resume-update" command to continue the automated update of the cluster.
Syslog Message
The automated update of the cluster has been paused due to a request by the operator.
(None).
upgrademgr.update.resumed
Severity
INFORMATIONAL
This message occurs when the automated update of the cluster is resumed from the paused state.
Corrective Action
(None).
Syslog Message
The automated update of the cluster has been resumed by the operator.
(None).
upgrademgr.update.started
Severity
NOTICE
This message occurs when the upgrade manager begins an automated update of the cluster. By default, nodes that are already upgraded to the target version are skipped, except for MetroCluster configurations.
Corrective Action
(None).
Syslog Message
An automated update of the cluster has been started on nodes:%s. Skipped nodes:%s.
nodestoUpgrade (STRING): Nodes that will be upgraded
nodesSkipped (STRING): Nodes that will be skipped, or "none" if all nodes need an upgrade, or "disabled - MetroCluster" if the cluster is a MetroCluster configuration, or "disabled" if the "-skip-nodes-at-target-version" parameter is set to false.
