exports.policy events
exports.policy EMS events occur when ONTAP encounters issues associated with export policy configuration.
exports.policy.empty
- Severity
NOTICE
- Description
This message occurs when an export policy with no rules is assigned to a volume or a qtree. Such an empty policy makes the volume or qtree inaccessible to NFS and CIFS protocol clients.
- Corrective Action
If access is needed for the volume or qtree, then create an export policy rule using the "export-policy rule create" command.
- Syslog Message
An export policy "%s" with no rules was assigned to a %s "%s" on the Vserver %s.
- Parameters
policyName (STRING): Name of the export policy with no rules.
type (STRING): Type of object (volume or qtree).
typeName (STRING): Name of the volume or qtree.
vserver (STRING): Name of the Vserver with this issue.
exports.policy.last.rule
- Severity
ERROR
- Description
This message occurs when the last rule from the export policy assigned to a volume or qtree is deleted. An empty policy will make the volume or qtree inaccessible to clients using NFS or CIFS protocol.
- Corrective Action
- Syslog Message
The last rule from export policy "%s" was deleted on Vserver %s.
- Parameters
policyName (STRING): Name of the export policy from which the rule is being deleted.
vserver (STRING): Name of the Vserver where the issue occurs.
