ONTAP EMS reference
exports.policy events
exports.policy.empty
Severity
NOTICE
This message occurs when an export policy with no rules is assigned to a volume or a qtree. Such an empty policy makes the volume or qtree inaccessible to NFS and CIFS protocol clients.
Corrective Action
If access is needed for the volume or qtree, then create an export policy rule using the "export-policy rule create" command.
Syslog Message
An export policy "%s" with no rules was assigned to a %s "%s" on the Vserver %s.
policyName (STRING): Name of the export policy with no rules.
type (STRING): Type of object (volume or qtree).
typeName (STRING): Name of the volume or qtree.
vserver (STRING): Name of the Vserver with this issue.
exports.policy.last.rule
Severity
ERROR
This message occurs when the last rule from the export policy assigned to a volume or qtree is deleted. An empty policy will make the volume or qtree inaccessible to clients using NFS or CIFS protocol.
Corrective Action
Syslog Message
The last rule from export policy "%s" was deleted on Vserver %s.
policyName (STRING): Name of the export policy from which the rule is being deleted.
vserver (STRING): Name of the Vserver where the issue occurs.
